Breiz
Jan 05, 2022Aspirant
[RAX70] Wifi - SSID 5G-2 in Mode 'Up to 4803 Mbps' doesn't show up
Hi, I have noticed a quirk in the wifi setup on the RAX70 with regards to the 5G-2 SSID. When I select the Mode 'Up to 4803 Mbps', it takes ages for the SSID to show up and you can't connect ...
- Jan 05, 2022
do you live in an area with radar (military, weather, or satellite communication)? the "up to 4800" speed requires the use of DFS channels which have certain restrictions. When the router boots up, it has to scan/check those channels before it can broadcast on them (takes longer). And if it senses those channels in use with radar, it can't use them until a set period of time after they've stopped broadcasting.
Jan 05, 2022Guru - Experienced User
FYI, I've not been able to see anything near 4800Mpbs speeds on any Netgear wifi product. Closest I've ever seen is around 4200Mpbs and thats at close range, 6-8 feet. Practicallity wise, most will not ever see this speed rate on a daily basis due to distances, wifi conditions and building materials. I kind wish router Mfrs would stop marketing this wifi speed rate.
