Benjamin123
Dec 28, 2021Aspirant
RAX75 unable to access router settings using my iOS devises. But will work on brothers android phone
Hello all, thank you in advance for your help. I’ve been trying for DAYS to access my router settings via my iPhone 12 or iPad Pro (while connected to my wifi network of course) with no luck. Those a...
Dec 28, 2021Guru - Experienced User
Most mobile phone access to routers is done thru the Nighyhawk app.
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
- Benjamin123Dec 29, 2021AspirantOk thanks for the heads up, really appreciated it. I’ll repost it there as well.
- FURRYe38Dec 29, 2021Guru - Experienced User
