klaus_0826
Oct 18, 2021Guide
RAX80 - Netzwerk-Auslastung
Hallo Ich habe in meinem Netzwerk 3 Synology NAS, welche via Kabel mit meinem RAX80-Router verbunden sind. Auf dem Synology NAS 1817+ habe ich ca. 9 TB Daten abgelegt, von denen ich regelmässig mitt...
- Oct 18, 2021
Hi plemans
You are completely right! I was misled and mixing up things when I was looking at my internet subscription ... That's another issue; sorry for that!
We are talking about the LAN connections between my RAX80 and my NAS's... If I understand you correctly there is not much one can do about the lack of performance there. So I will try to better organize my backup process and use mainly the 'idle' time during the night in order to gain some additional processing power and more efficiency. Anyhow, I got some uselful information from you.
I will close the thread ...
Thanks for your help and kind regards
Klaus
schumaku
Oct 18, 2021Guru - Experienced User
plemans wrote:
You're probably right the ethernet link is the bottleneck.
Yes, of course.
plemans wrote:
You can always upgrade to a 10gig connection if you'd like. Its a lot more expensive in terms of router, connection in the computer, and NAS but you'll be able to move data faster.
Unless you have an Internet connection going beyond 1 Gb/s there is no need to update the router. Most ISP supplied CPE for faster Internet connections offer at least some 2.5/5 or 10G LAN port.
No question, a 10G network requires a 10G (better MultiGig) capable switch, 10G adapters on the NAS and the computers to take an advantage out of it.
klaus_0826
Oct 18, 2021Guide
Hi plemans
Thank you for your reply.
I currently have an internet with 500 Mbit/s download and 50 Mbit/s upload. The provider offers now a Giga net with an upload speed of 1 Gbit/s and 100 mbit/s on download. Pricewise the upgrade would cost me about 20$ per month which seems pretty reasonable to me. The question for me is if my RAX80 could really take advantage of the increased speed and provide me with higher data transfer rates...
Would you from a technical point of view suggest a change to the Giga net?
Thank you for your advice and best regards
Klaus
- plemansOct 18, 2021Guru - Experienced User
If your main data transfer is all on your internal LAN network, then it doesn't really matter what speeds you pay your ISP for.
You could have a 10mbps connection from your isp but if you're doing backup to a NAS on your internal LAN, you could run at 100x the speed (if you had the capability).
I guess I'm trying to figure out what issue you're trying to fix?
You description of the issue followed by your response don't make a lot of sense.
- klaus_0826Oct 18, 2021Guide
Hi plemans
Klaus
- FURRYe38Oct 18, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Please be sure to visit and post there for yoru future needs:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6Please use this link to the main forum product list to review and choose where to make your posts.
Thank you.
