Gadgetjq
Aug 26, 2021Aspirant
RAX80 Breaks With Reserved IP Addresses?
RAX80. I recently went on a 'tidy up' binge and reserved IP addresses for all of my iot devices (Echo, smart plugs etc). I already had reservations for a half dozen or so items (printer, nas, compute...
Gadgetjq
Hi Furry,
Thanks for the response.
I set 29 IP reservations total from 192.168.1.200 to 192.168.1.229. The router is set to be used as a DHCP server addresses 142-240. With 98 IP addresses available I have 84 devices connected (about 1/3 of those wired).
I understand the difference between static and reservations. I don't even think you 'can' create a static address for iot devices.
Yes, the firmware update was followed by the router's normal reboot then I did a complete power off reboot.
As things stand now everything is working fine (and did before I reserved the batch of addresses). I just can't figure out 'why' the reservations prevented so many other devices from connecting.
I'm certainly open to any suggestions.
Cheers!
Aug 26, 2021Guru - Experienced User
- GadgetjqAug 26, 2021Aspirant
No. I'm not ready to start from scratch for an issue that's solved by deleting reserved IP addresses.
My question is simply is blocking new connections when more than a few IP addresses are reserved a quirk of this router? If not what's the workaround. It shouldn't require a factory reset.
Cheers!- FURRYe38Aug 26, 2021Guru - Experienced User
Resets are a valid troubleshooting step.
Good Luck.
