Gadgetjq
Aug 26, 2021Aspirant
RAX80 Breaks With Reserved IP Addresses?
RAX80. I recently went on a 'tidy up' binge and reserved IP addresses for all of my iot devices (Echo, smart plugs etc). I already had reservations for a half dozen or so items (printer, nas, compute...
Gadgetjq
No. I'm not ready to start from scratch for an issue that's solved by deleting reserved IP addresses.
My question is simply is blocking new connections when more than a few IP addresses are reserved a quirk of this router? If not what's the workaround. It shouldn't require a factory reset.
Cheers!
Aug 26, 2021Guru - Experienced User
Resets are a valid troubleshooting step.
Good Luck.
