mateverywhere
Oct 19, 2021Aspirant
RAX80 will not save ‘Short Preamble’ with 5GHz
I've never been able to get my RAX80 to save 'Short Preamble' against the 5GHz network. For the 2.4, it saves without issue. Using the latest firmware as of today. Not using Smart Connect. Ha...
- Oct 20, 2021
Thanks! I have re-posted here.
NOTE: This isn't a solved as yet.
Oct 20, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
- mateverywhereOct 20, 2021Aspirant
