golways
Aug 27, 2021Aspirant
RAXE500 - Using 6 Ghz wifi network in France
Hi all, I bought my RAXE500 router in May in the USA and use it in FRANCE. It works fine, except wifi 6 Ghz band. Right now, the wifi 6 Ghz network is invisible to my Samsung Galaxy S21 Ultra a...
Aug 27, 2021Guru - Experienced User
It might be approved but not sure if its made it into the firmware changes yet. There's usually a lag between approval and firmware changes.
Does it work if you change the region to a not france region?
(just to test)
maybe Altsai has an idea if its going to be released for france region
golways
Thank you for your help.
Region is set to North America and that cannot be changed...
Franck
