golways
Aug 27, 2021Aspirant
RAXE500 - Using 6 Ghz wifi network in France
Hi all, I bought my RAXE500 router in May in the USA and use it in FRANCE. It works fine, except wifi 6 Ghz band. Right now, the wifi 6 Ghz network is invisible to my Samsung Galaxy S21 Ultra a...
golways
Thank you for your help.
Region is set to North America and that cannot be changed...
Franck
Aug 27, 2021Guru - Experienced User
Your region is north america?
And is your region for the s21 north america?
If its set to north america it shouldn't be under the france broadcast restrictions
- golwaysAug 27, 2021Aspirant
Region is North America in RAXE500 firmware (and cannot be changed).
S21 and TV were bought in France and have french version firmwares.
- plemansAug 27, 2021Guru - Experienced User
golways wrote:
Region is North America in RAXE500 firmware (and cannot be changed).----it can with a little googling. google netgear burnsku unlock
S21 and TV were bought in France and have french version firmwares.-----so you have a router that can broadcast 6e but your equipment (s21) might not be enabled because its firmware is a french version that might not have the updated firmware to do so. I'm not sure what to tell you on what the best way to find out if its broadcasting or not because so few devices can pickup 6ghz. And if the devices that can pick it up are in a region that might not have the firmware enabled, then it gets skewed.
