golways
Aug 27, 2021Aspirant
RAXE500 - Using 6 Ghz wifi network in France
Hi all, I bought my RAXE500 router in May in the USA and use it in FRANCE. It works fine, except wifi 6 Ghz band. Right now, the wifi 6 Ghz network is invisible to my Samsung Galaxy S21 Ultra a...
michaelkenward
Aug 28, 2021Guru - Experienced User
golways wrote:
Thank you for your help.
Region is set to North America and that cannot be changed...
Franck
Stuff sold in the USA tends to be more severe in hard wring the region.
There are way to force some hardware to "move".
Different hardware, possibly same approach:
Solved: WNDR3700v2 (N600) - Can't change wifi region - NETGEAR Communities.
And:
Search - NETGEAR Communities – burnsku
golways
Aug 28, 2021Aspirant
Hi guys,
thank you for your great help. But for the moment, I did not succeed in changing region to Europe (or something else).
First, I tried to allow telnet connection to RAXE500:
- the http://www.routerlogin.net/debug.htm page exists but has no telnet case to check.
- I downloaded the telnetenable python script that works for some Netgear routers, made a python 3.8 version (the script on the net is old and for python 2), and run it with no error with my router parameters, but it did not unable RAXE500 telnet connections.
Secondly, I tried to change the region through the router web interface, with chrome development tools. In the RAXE500 wifi parameters page, I located in html objects the Region select and executed 'document.getElementById("wireless_region").removeAttribute("disabled");' in the console to unable the select in the page. I could then change the region and I applied changes to the router. But when the router finished applying changes, I saw the region was still North America...
So no solution for the moment. I keep on searching...
- michaelkenwardAug 28, 2021Guru - Experienced User
Netgear is steadily removing Telnet from the things you can do on a router.
- plemansAug 30, 2021Guru - Experienced User
You should change the region but I'm not sure if t hat's in your best interest for the RAXE yet if the firmware doesn't have 6g built in for france yet.
I'd focus more on making sure your phone/computer can use 6E with the france firmware on them.
