xavierprof2's avatar
xavierprof2
Follower
Oct 13, 2021
RBK53 bloque sur "veuillez patienter" interface web box orange fibre
Bonjour
Je viens de passer à le Fibre chez Orange avec une livebox 5.
J'arrive à me connecter à mon Netgear Orbi RBk53 depuis un navigateur WEB (Safari, Mozilla, Edge...), mais l'interface WEB ne charge pas. Elle reste bloqué sur "veuillez patienter quelques instants...".
Tout fonctionne bien depuis l'application iPhone, mais pas depuis un PC Windows 10 ou un MAC OSX. Seul les commande sur la gauche de la page apparaissent. Le centre de la page WEB reste vide.
Merci pour l'aide.
  • FURRYe38's avatar
    en anglais s'il vous plaît
    Netgear has set up a community forum specifically for the Orbi AC (WiFi 5) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi/bd-p/Orbi
    Thank you.
  • plemans's avatar
    Livebox is its own router and has its own routing functions.
    It causes a double nat and can sometimes cause issues.
    A double nat happens when you cascade more than 1 router.
    https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
    Fixes? There’s 3 options but only use 1.
    1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
    2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
    3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
    https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
