Chikey's avatar
Chikey
Follower
Sep 06, 2021
RBR20
I Have researched but I've been unable to find: How do I reset my Orbi account email address login? I no longer have access to the email address used to create the logon account. All it will let me do is reset password, but I need the account email changed.
thanks,
Bruce
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Which Orbi account? (Netgear has a plethora of different "accounts".) What do you use it for?
    Login to what?
    What are you doing when this happens?
    You don't need an account to set up and use a router.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Orbi - NETGEAR Communities
    Those things are different from the standard Netgear routers covered in this section.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
