TT19's avatar
TT19
RBR50 Router Won't Stop Pulsing White
Was having an issue with a Roku device.  Restarted my modem.  Upon restarting the modem, the RBR50 blinked white at first and then pulses white.  It stayed that way for about 15 mintues.  Tried to do a factory reset by using a paper clip.  The power light blinked amber as indicated it would, but the pulsing whilte never stopped.  I am at a loss at what to try next.  Wondering if my entire Orbi system is now fried.
Would appreciate any help that can be given.
  • Added info.  Still pulsing white.  However, Roku devices will connect while it is pulsing white and can stream, but phones, laptops, etc. will not stream.  All connect, but some without "internet."   Now I am really confused.
1 Reply
