Ka18's avatar
Ka18
Follower
Oct 09, 2021
RBR50
Mes appels WhatsApp en wifi coupent au bout de quelques secondes ; j’ai essayé la manipulation de désactiver la fonction Lan/ comme indiqué pour un autre utilisateur dans un autre post mais cela ne fonctionne toujours pas !
1 Reply
  • plemans's avatar
    well you posted in the nighthawk forum about an orbi device and gave us minimal info.
    here's the fourm for orbi.
    https://community.netgear.com/t5/Orbi/bd-p/Orbi
    include more details like:
    firmware you're on?
    modem/gateway your connected to?
    device having issue?
    is it on all devices or just one?
    are you connected to 2.4ghz or 5ghz when it happens?
    Is it only the 1 app with issues?
