Bizzygirl
Oct 08, 2021Aspirant
RBR50v2 how do I tell if base unit is ready to sync?
I had to get a new modem and have reset and plugged in, it has pulsed white light but now no light is showing. I need to make sure everyone is available to reset and link the units, but I want to make certain it is ready.
thanks
what modem did you get?
Are you able to log into the router and check its status/settings?- BizzygirlAspirant
How do I log in to it? I don't know where to start wit this. RBR50v2
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.
There may also be some helpful videos on what to do.You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
