billybo
Jan 23, 2022Aspirant
RBR850 limiting guest account
Looking for a way to limit the bandwidth on the guest network. have the RBR850 with a satellite running in Router Mode to a Telus wi-fi router.
- Jan 27, 2022
The isn't any bandwidth limiting features on Orbi AX systems.
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
michaelkenward
Jan 24, 2022Guru - Experienced User
That probably depends on the Orbi hardware you are using.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
