techristian's avatar
techristian
Initiate
Aug 18, 2021
200 mbps directly from NightHawk GS3000 and only 90 mbps thru NETGEAR GS308 SWITCH
  So since I just bought this new NETGEAR GS3000 NightHawk , I figured that I would get a NETGEAR SWITCH to go with it. I bought the GS308 but it isn't passing through the same speed as it is receiv...
  • plemans's avatar
    Aug 18, 2021
    Try swapping out cables. A sketchy cat 5e cable can sometimes cause the connection to be 10/100mbps and not gigabit.
    Either make sure its a quality cat 5e or cat 6 cable.
