steeves
Nov 09, 2020Aspirant
5ET199BBA0134
R6350 — AC1750 Smart WiFi Router Wi-Fi 5 Dual Band Gigabit I look at spec and I could not find the output power at theses 4 modes (25,50,75&100%) and the antenna gain on my router. Can you plea...
Nov 09, 2020Guru - Experienced User
maybe the reason you're trying to find this out is more beneficial than random questions?
Are you trying to reach a certain distance? Trying to decrease power levels to a certain point?
what exactly is your goal?
steeves
Do you yes or no have anwser to my initial question..? otherwise i will simply measure it in one of our facility.
- plemansNov 09, 2020Guru - Experienced User
This is the community support forum. Where members of the public help out.
You can look it up through the fcc if you'd like .
