Hopper15
Aug 09, 2021Star
7/29/21 - Firmware update 1.0.4.74
Anyone having issues with this firmware update version 1.0.4.74? Ever since I updated my router's firmware to this version my browser(mozilla firefox) has been having issues connecting to webpages. T...
- Mar 15, 2022
Recommended build to use currently is v.62:
https://www.netgear.com/support/product/r8000.aspx#Firmware%20Version%201.0.4.62
curlykid1
Sep 20, 2021Initiate
Can confirm that the new firmware has the same DNS issue as previous version (.74).
Would you be willing to share that test firmware with me?
Winancy
Sep 20, 2021Apprentice
I'm betting even though there's a trail of tech support, I won't be given a partial refund for the Netgear Nighthawk they bricked with the update. I've already thrown it out, so no update will help me. I don't think I should be expected to deal with that DNS crap for months while they figure it out.
- michaelkenwardSep 21, 2021Guru - Experienced User
Winancy wrote:
.... the Netgear Nighthawk they bricked with the update.
Bricked in what sense? I ask because people have been known to abuse that label.
- robjakSep 21, 2021Luminary
Fairly certain that winancy's router had issues with DNS even after the roll back of FW. so once it did the update he was stuck with the DNS problem. He had no recourse but to replace the router. In my case, the roll back fixed my issue.
- WinancySep 21, 2021ApprenticeShe. And you're correct. I rolled back and it didn't correct the problem. And when I downloaded the newer update, it still had the DNS issue.
