Mike_Soda
Apr 13, 2022Aspirant
7800 Client Mode?
Is it possible to setup my R7800 as a client? I used to have my own connection through Sparklight I originally bought it for a couple years ago. Unfortunately now I'm in an appartment & trying to avoi...
Apr 14, 2022Guru - Experienced User
Should connect fine.
Mike_Soda
Apr 14, 2022Aspirant
Unfortunately it wont, settings attempt to apply but then the page refreshes & says unable to connect. From that point forward I can't log into my modem at all. Acts as if it's bricked, have to use that tiny pin reset button on back to reset the modem to factory defaults.
- plemansApr 15, 2022Guru - Experienced User
What modem do you have? the R7800 is a router only device.
- Mike_SodaApr 19, 2022AspirantDo you mean the one I'm trying to bridge with? It's Hiltron our landlord leases from Sparklight. I'm not sure model number. As for mine it's a Nighthawk X4S AC2600 R7800.
- FURRYe38Apr 15, 2022Guru - Experienced User
Are you setting up the R7800 for Dynamic or static IP addressing when configuring the Bridge mode settings?
How is the modems wifi configured? SSID name, CHANNELS and WPA mode?
"Probably a Hiltron CGNM-2250."
Mike_Soda wrote:
Unfortunately it wont, settings attempt to apply but then the page refreshes & says unable to connect. From that point forward I can't log into my modem at all. Acts as if it's bricked, have to use that tiny pin reset button on back to reset the modem to factory defaults.- Mike_SodaApr 19, 2022AspirantDynamic IP, I've been trying the 5ghz channel option, with or without the 5G suffex doesn't seem to matter. Attached in 3 replies because of limit are pics of everything so you can cross examine. I've looked over a dozen times though, matches up, should work.
- Mike_SodaApr 19, 2022AspirantMy Bridge Settings
- Mike_SodaApr 19, 2022AspirantBridge Wireless Info
- FURRYe38Apr 20, 2022Guru - Experienced User
That should work.
Look at the R7800s Advanced tab page to see the status of the connection...
