Mike_Soda
Apr 13, 2022Aspirant
7800 Client Mode?
Is it possible to setup my R7800 as a client? I used to have my own connection through Sparklight I originally bought it for a couple years ago. Unfortunately now I'm in an appartment & trying to avoi...
Apr 15, 2022Guru - Experienced User
Are you setting up the R7800 for Dynamic or static IP addressing when configuring the Bridge mode settings?
How is the modems wifi configured? SSID name, CHANNELS and WPA mode?
"Probably a Hiltron CGNM-2250."
Mike_Soda wrote:
Unfortunately it wont, settings attempt to apply but then the page refreshes & says unable to connect. From that point forward I can't log into my modem at all. Acts as if it's bricked, have to use that tiny pin reset button on back to reset the modem to factory defaults.
Mike_Soda
Apr 19, 2022Aspirant
My Bridge Settings
