Mike_Soda
Apr 13, 2022Aspirant
7800 Client Mode?
Is it possible to setup my R7800 as a client? I used to have my own connection through Sparklight I originally bought it for a couple years ago. Unfortunately now I'm in an appartment & trying to avoi...
Apr 20, 2022Guru - Experienced User
That should work.
Look at the R7800s Advanced tab page to see the status of the connection...
Mike_Soda
Apr 29, 2022Aspirant
I can't, once I apply the settings for bridge mode it logs me out of the router & is inable to sign back in. I have to factory reset in order to sign in & setup router with default settings all over again. At that time it just says disconnected no internet access.
- FURRYe38Apr 29, 2022Guru - Experienced User
If you set a static IP while in the same range on the R7800 for bridge mode as the host routers IP address pool range, you can access the R7800 while in bridge mode using the IP address you input for static IP. I used 192.168.#.78.
- Mike_SodaMay 07, 2022AspirantSo I need to change my landlords dns ip or mine in bridge mode? Their hiltron dns ip is set to auto which I guess is dynamic so it doesn't say. How do I find out what the host routers ip range is?
- FURRYe38May 07, 2022Guru - Experienced User
Just use there routers IP address for DNS or you can use any DNS on the R7800 side while in bridge mode.
You'll need to ask the landlord to take a look at the routers IP address pool size on that unit 192168.1.2 thru .254 maybe seen. Might ask if they can make this 192.168.1.100 to .250. Then you could set a static on the R7800 for 192.168.1.78.
- Mike_SodaMay 19, 2022AspirantThe only information within their router I can find is Private LAN IP Adress: 192.168.0.1/24. From what I can tell there's no way to change the 24 to a different value. I tried to set the DNS to the routers IP which I think is 192.168.0.1. Left the part about Get IP Address Dynamically alone though. I'll just screenshot everything because I can't figure it out.
- Mike_SodaMay 19, 2022AspirantHere's bridge mode settings menu, I just need to know what I've done wrong & what to put where based off images that'll follow.
- Mike_SodaMay 19, 2022AspirantLandlords routers settings
- Mike_SodaMay 19, 2022AspirantMore
- Mike_SodaMay 19, 2022AspirantMore settings
- Mike_SodaMay 19, 2022Aspirant5g settings
- Mike_SodaMay 19, 2022Aspirant2.4g settings
