Mike_Soda
Apr 13, 2022Aspirant
7800 Client Mode?
Is it possible to setup my R7800 as a client? I used to have my own connection through Sparklight I originally bought it for a couple years ago. Unfortunately now I'm in an appartment & trying to avoi...
May 07, 2022Guru - Experienced User
Just use there routers IP address for DNS or you can use any DNS on the R7800 side while in bridge mode.
You'll need to ask the landlord to take a look at the routers IP address pool size on that unit 192168.1.2 thru .254 maybe seen. Might ask if they can make this 192.168.1.100 to .250. Then you could set a static on the R7800 for 192.168.1.78.
Mike_Soda
May 19, 2022Aspirant
More
