Mikecc419
Feb 18, 2021Aspirant
Ac2300 R7000P cant connect to reolink battery operated camera
Had a older N600 router that worker fine with camera have checked everything Reolink has suggested except for this. Cause 7. The Wi-Fi frequency is out of supported range Solution: Please set the ro...
Feb 18, 2021Guru - Experienced User
the R7000P only supports 20/40hz for the 2.4ghz channel.
What firmware is on the router?
What gateway/modem is it connected to?
what issue do you run into during setup?
What camera is it?
when you're setting it up, is your phone connected to 2.4ghz?
What 2.4ghz channel are you using on the router?
Mikecc419
The gateway modem is what was supplied by spectrum same modem was in use on the older n600 router all that us new is the ac2300 nighthawk
