Mikecc419
Feb 18, 2021Aspirant
Ac2300 R7000P cant connect to reolink battery operated camera
Had a older N600 router that worker fine with camera have checked everything Reolink has suggested except for this. Cause 7. The Wi-Fi frequency is out of supported range Solution: Please set the ro...
Feb 18, 2021Guru - Experienced User
The reason I ask is since netgear added armor to the R7000P, there's been a few devices with issues.
The lastest version is 1.3.2.134
the one I usually recommend if people are having issues is 1.3.0.20
any firmware changes I recommend be done over a hardwired connection followed by a factory reset and a clean install (not using a backup config)
Mikecc419
Feb 26, 2021Aspirant
Went back to the old router camera woundnt connect to it either. Bout a new camera all is well now
