Boggs0009's avatar
Boggs0009
Follower
Oct 04, 2024
Re: ac2300 speed is slower than it should be
I just purchased and installed the same router as you (Nighthawk AC2300 R7000P) along side a Nether CM600 Modem and experienced the same cap. Same as you, I bypassed the router and did a speed test wh...
