millertime23
Aug 25, 2021Aspirant
Can no longer VPN into port 443 on R7000
I had TCP port 443 configured for the openvpn settings on my R7000 router and it was working perfectly. After the firmware upgrade to v1.0.11.126_10.2.112 my VPN will no longer connect. I tried...
michaelkenward
Aug 25, 2021Guru - Experienced User
Your call. A VPN that might work versus a possibly useful security improvement.
You can check to see if the firmware caused the problem and then decide which way to jump.
millertime23
I've been considering flashing DD-WRT if I can't find a fix for this. I prefer to keep stock firmware, but if I'm forced to downgrade firmware to fix this I'd rather install the latest DD-WRT instead
