johnsmith5's avatar
johnsmith5
Re: Cannot reach 1 website only
Jccasey22 wrote:
I am unable to reach one website only, my company's website, at this time. I have done a full factory reset on my NightHawk AC1750 C6300v2 as well as several full resets of my computer. I am using Chrome on macOS. This issue has come up before, but usually only lasts a few minutes. It has been blocking my access to my website for a full 24 hours now.
I have changed DNS settings, and cannot find a way to see if this is a firewall situation within the Nighthawk app or in the advanced settings on netgear.
To make sure it wasn't a wifi issue or a mac issue, I have plugged a separate PC into the ethernet cord and have the same issue.
The website is working find and is accessibel to my entire team, and also works fine if I access it through my data plan.
Is this a faulty router issue?
 i was also facing the same issue and i found that my router needs to restart therefore i restarted it and it start working speedily ,my official business site was not loading properly
  • FURRYe38's avatar
    What NG router do you have?
    What web site are you referring too?
    What web browser are you using?
    Happens with different PCs or mobile devices?
