virtualgeorge
Sep 08, 2022Aspirant
Can't connect to 2.4 but 5g still works?
I have centurylink and a C2000T modem. I have a Nighthawk 7450 dual band that has been working fine for years but after power outage I suddenly can't connect any of my devices to the 2.4 network. See...
Sep 08, 2022Guru - Experienced User
Is your c2000t in passthrough mode?
Also, you might try factory resetting the router and reinstalling. Storms do great at breaking or corrupting things. It might have corrupted something in the settings.
virtualgeorge
Yes I believe so, transparent bridging, right?
It took me a while to figure out how to configure the nighthawk modem several years ago initially, but I suppose I could just screenshot the current settings and then reset & try again to re-enter the settings?
thx much!!
