dbonneville
Mar 26, 2019Follower
Can't get Time Machine to work with Nighthawk
 Mac OS Mojave 10.14.3
 Nighthawk(R) X4S R7800
 Router Firmware Version  V1.0.2.62 (just updated)
 I bought a new 1TB Seagate SSD external HD. I formatted it according to the instructions low...
metrologuy
Mar 17, 2020Aspirant
Oh so close. Your detailed instructions are great. But when I try to backup with the HD connected to the router, I get a Time Machine failure "don't have required permissions" to write to the disk. I can't change the permissions to Read&Write. Any way around this? Thanks again.
wkuchrisn
Mar 17, 2020Star
Does it work when it's connected directly? Was it a clean drive beforehand and you formatted it during this process?
