cjpattinson
Apr 05, 2020Tutor
Can't Rename Attached Devices, Can't Change QOS Settings for Attached Devices
Product: Nighthawk X6 R8000 - Firmware V1.0.4.46_10.1.63 Hi Folks Need help trying to solve a problem where I cannot change device name or QOS settings for attached devices. I go through usua...
- Apr 06, 2020
Thank you James, you are exactly correct.
Maybe "Never" is a stretch and instead, "Not Always the Best Practice" would have been a more appropriate responce, but I do feel that it is realitive to these forums and is worth mentioning.
