Firecapt1
Apr 05, 2018Aspirant
Can't seem to hide/disable SSID broadcast
Just got my router today, it's all set up and working well except I can't seem to disable the SSID broadcast for the WiFi. I know that the box that says "Enable SSID Broadcast " should be unchecked,...
- May 29, 2018
I did a factory reset on the router and that seems to have solved the problem. Thanks to everyone for the help! :smileyvery-happy:
JamesGL
May 04, 2018Master
Hi Firecapt1,
Have you tried to reset the router to factory default?
