Lethal57
Dec 25, 2020Guide
Re-connection of R6400v2
Hi, Background. I had to disconnect my netgear router, as I joined the neilsen broadband panel survey for a few months. However I got sick relying on my providers wifi router (Optus) for wifi.....
michaelkenward
Dec 26, 2020Guru - Experienced User
Lethal57 wrote:
My question is I have two powerline adapters plugged into the netgear router. However (unlike previously) the lights on the netgear continue to show red. I have restart the router and powerline adapter sender units, with no change/impact.
Is this the problem you are trying to fix? Or is there something else amiss on your network?
If it is just the Powerline plugs, it would help if you said what they are (the model) and what lights we are talking about. Mine have three lights.
You might also get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Powerline Networking - NETGEAR Communities
- Lethal57Dec 26, 2020Guide
Hi Michael Kenward,
The issue is a device issue.
I am trying to work out WHY I am getting red lights on the Device.
I have not tested the powerline adapters as yet (little need so far).
Both powerline adapters have three lights.
One powerline is a foxtel powerline adapter (common)
The other is one sold to me by my isp when I was recontracting for Fetch TV. I can provide you the details of this one.
I have now reconnected all linked extenders in the house, so the wifi is working well, and ithe device is also supplying internet to the main pc by ethernet...its just a little perplexing why, suddenly I am seeing these red lights....
- michaelkenwardDec 26, 2020Guru - Experienced User
Which device is that?
Then there is this bit:
Which lights? The R6400 has a dozen to pick from. To see what the colours mean check the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.Check the sections LED and button descriptions and Troubleshoot With the LEDs.
You may have done this already. I can't tell from your message.
So where do they come into the picture? I assume that you mentioned them for a reason.
Thanks for the subsequent response Michael.
I am not sure if you are trying to be antagonistic or not, however I refer to the lights on RH side of the above device...the ones that address each ethernet cable connected.
Communities or Forums participants generally ask for clarification. I dont call what you have imparted (apart from the navigation suggestions) beneficial for either of us.
The TWO cables I have connected to powerline adapters (sending units),are the ONLY ports with lights that remain red.
So yes, there was a 'reason' for mentioning these.
They were also alluded too or mentioned in yours and my prior posts.
Kindly see attached photo.
In the interim I will visit the support pages.
However is someone has something productive/postive to add (ususally expected in a community), I look forward to reading it.
