yagirlchels
May 06, 2021Aspirant
CONSTANT DOS ATTACKS & DISCONNECTION
[ Spoiler ] For the last two weeks, my internet has been acting up and keeps just randomly disconnecting. Only for a couple of seconds but it happens back to back all day long. Can someone help me u...
carapungo
Nov 04, 2021Aspirant
were you able to fix this issue?, what was causing it, and what was the solution?
yagirlchels
Nov 05, 2021Aspirant
So, I actually had to contact my ISP (xfinity) and end up getting an entirely new IP address for my router. Nothing else was working. I havent had an issue since then.
- FURRYe38Nov 05, 2021Guru - Experienced User
Sounds like this was coming in from the ISP side then.
Please mark your thread as solved so others will know.
Enjoy.
