Smokesignal3
Jul 09, 2024Aspirant
Re: Current Firmware update for my R7000 AC1900
My WiFi is not working.
Smokesignal3
michaelkenward
Jul 26, 2024Guru - Experienced User
Your picture suggests that the wifi is turned off.
First try pressing the wifi LED to see if it will come back on. Look at the2.4 and 5 GHz LEDs.
Do not rush to reset the router until you have done some more investigation of what is happening on at your end. That is a brute force move. It is rarely needed to fix most issues. If the switch doesn't work, tell us more about your network.
Looks like you also have some slow (100 Mbps) devices connected to your LAN ports.
Your "modem" – the box on the left? – also has four LAN ports, suggesting that it is also a router. So maybe you are piling router on router. That can cause problems.
