Clear_light
Feb 04, 2022Aspirant
Did a factory reset and now netgear wont let me log in via ISP - keeps redirecting to Nighthawk APP
Hi, I had to do a factory reset and now I'm trying to log back in and set things up -- without using the nighthawk app. But every time I type in Http://192.168.1.1, I am redirected to a page to down...
- Feb 04, 2022
Thank you. I did scroll to the bottom and click, but I kept getting redirected to Netgear web pages.
I finally figured it out. I had to disable VPN and brave shield.
michaelkenward
Feb 04, 2022Guru - Experienced User
Good research. Which VPN?
Let that be a lesson to anyone who has a network with that sort of complication. These things exist to mess around with P addresses. No wonder they get in he way of your browser.
I put the model number in the body of my post, so I'm not sure why it did not show?
You did. It was there, which is why no one asked for that.
It was the modem that we needed to know about. Fortunately, you have nothing complicated on that front. Just a cable modem with voice.
Clear_light
Feb 05, 2022Aspirant
Thank you. I'm using Mullvad VPN.
- michaelkenwardFeb 05, 2022Guru - Experienced User
Many thanks for that. It might help future victims!
