Networkingjoe
May 09, 2024Aspirant
Disable external Access
How do you disable http access to the router. When I type http://myip into a browser, I get a login prompt to routerlogin. How do I disable that?
- May 09, 2024
Are you trying this from a remote location outside the home or trying this while at home on the same network?
May 09, 2024Guru - Experienced User
Check for Remote Access features under advanced Tab, Security or Admin. If you seen check box for this feature, uncheck the box and apply.
What FW version is loaded on your router?
Networkingjoe
I do not have Remote Access features anywhere. My FW is V1.0.11.216_10.2.122, which was the latest 2 weeks ago.
