Neliz89
Dec 27, 2021Aspirant
Dispositivi Collegati
Buonasera, è da un p odi tempo che ho problemi legato alla gestione dei dispositivi collegati al mio R9000. Come potete vedere in allegato è davvero un disastro la gestione.....si sdoppiano gli ip,...
Dec 28, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update using a wried PC and Web browser? MS Edge or FireFox.
Neliz89 wrote:
Good evening, I have been having problems managing the devices connected to my R9000 for a while now. As you can see in the attachment, the management is really a disaster ..... the IPs are doubled, the names in short, a torture! I've tried all browsers but the result doesn't change. Anyone have any advice? thank you A greeting
Neliz89
Dec 28, 2021Aspirant
Good morning, the latest version of the FW is 1.0.5.38 and I get to my R9000 router directly with the sfp fiber and provider I have Fastweb. Since the last update I have already performed a reset but without success. I've tried all browsers but the result doesn't change !!! Can you post me a screenshot of your connected devices? Just to understand if the problem is mine alone.
Thanks so much
