vdn20's avatar
vdn20
DoS attacks/WLAN access denial showing up. Not sure what to do.
I'm getting a lot of these entries in th Logs, is it normal?  While this is happening, on the home screen it keeps saying I'm not connected to the internet.  I have the Nighthawk X4 R7500v2 firmware ...
  • Babylon5's avatar
    Dec 11, 2015
    There’s nothing in that listing which I would be particularly concerned about, the frequency is not high so really should not be affecting your network, there could however be a more significant issue for your ISP network. Have you contacted your ISP to see if there are any current problems? What kind of service do you have e.g. cable or DSL and what is the brand and model number of your modem?
