carll76
Oct 07, 2015Apprentice
emailing logs
Hello, I have tried and failed to setup my R8000 to email me the log files. I'm using gmail and have set up the account,.
In the log file when I click send logs I get the following message...
- Oct 07, 2015
You misspelled GMail's SMTP server. It is smtp.gmail.com. If port 465 doesn't work, then try port 587.
You can also try aspmx.l.google.comat port 25. No username or password is required, but you can only send to GMail or Google Apps users.
carll76
Oct 16, 2015Apprentice
Stopped working :(
Dont know why... Have not changed anything..
Log says email sent... Gmail doesnt do anything.. Nothing in any of the Gmail folders.. No spam, nothing in sent :(..
JamesGL
Oct 16, 2015NETGEAR Employee Retired
Hi carll76,
Welcome to Community!
Please check the settings of your gmail and make sure it allows router events logs and alerts to go through your account.
1. Log in to your Gmail then go to Settings.
2. Click on Accounts and Import then click Other Google Account settings.
3. Go to Security Check-up.
4. Click on Disable access on less secure apps.
5. Select the radio button to turn ON Access to less secure apps.
6. To test if it will send the logs via email, go to the router logs option on the router's GUI then click on Send Log.
JamesGL
Community Team
