ballbearing
Aug 11, 2021Aspirant
Error No ethernet cable is plugged into the router internet port.
I have used this router for about 3 months and it has been working fine, then all of a sudden it quit and I went through everything in the manual. When I try to use the router login . net it just tel...
michaelkenward
Aug 13, 2021Guru - Experienced User
ballbearing wrote:
The internet which works perfectly is plugged into the yellow input of the router and the cable output is going to the PC.
Is there a modem of some sort in front of this router?
ballbearing
Aug 13, 2021Aspirant
Of coarse, it's a Netgear also, working fine straight out of it but nothing out of the router, just the error no internet plugged into the input.
- michaelkenwardAug 13, 2021Guru - Experienced User
A Netgear what? Does it have a model number?
Over the years, Netgear has made dozens of modems and modem/routers designed for particular types of Internet. Working out where your network goes wrong depends on knowing in detail what you are struggling to tame.
Please provide as much detail as possible. Leave it to us to decide what is relevant.
ballbearing wrote:
... working fine straight out of it but nothing out of the router
What does that mean? You can plug something into this magic box and connect something or other to the Internet?
Plenty of things that could go wrong there. But we need details.
The good news is that these things are usually pretty easy to fix. You just heed to go about it methodically.
- ballbearingAug 13, 2021Aspirant
The modem is a Netgear CM1000. Hope that helps. Thanks
- michaelkenwardAug 14, 2021Guru - Experienced User
That rules out one of the common causes of problems.A modem router in front of a router.
What about this not?
I'd go through the steps you have described again:
- Factory reset
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
- Restart the network as you described.
- Set it up yet again
I can't tell how you went about this to begin with: where possible do it with a browser and a wired connection into the router.
If there are still problems, then dive in and start the warranty process.
Start the RMA process by checking MyNetgear.
How do I request a Return Material Authorization (RMA)? | Answer | NETGEAR Support
- Factory reset
