ballbearing
Aug 11, 2021Aspirant
Error No ethernet cable is plugged into the router internet port.
I have used this router for about 3 months and it has been working fine, then all of a sudden it quit and I went through everything in the manual. When I try to use the router login . net it just tel...
ballbearing
Aug 14, 2021Aspirant
Been there already done that about 10 times. I have no warranty. Do you know how to diagnose the ports? Do I run the cable from the input to one of the outputs? And then check what? or does anyone else know anything to check? Thanks
ballbearing
Aug 15, 2021Aspirant
I did try it again and still no internet connection.
- ballbearingAug 15, 2021Aspirant
And also what you're asking about some magic box, no, it's not magic, just listen to what I say. If I bypass the router and hook the PC directly into the modem, it works fine. No magic whatsoever but when I put the router into the loop, no internet. Got it?
