KenDRider
Feb 24, 2018Aspirant
Extremely slow 2.4 GHz network
I was out of town and one of my security cameras reported it was offline and another was online but barely streaming. When I got home I noticed all of my Wifi connected devices were extremely slow. I...
- Jun 12, 2018
Hi All,
A new firmware update is available. Please update the firmware to 1.0.9.32
https://kb.netgear.com/000059134/R7000-Firmware-Version-1-0-9-32
Blanca
Community Team
michaelkenward
May 19, 2018Guru - Experienced User
More a hotfix than beta firmware:
R7000 Firmware Version 1.0.9.30 - Hot Fix | Answer | NETGEAR Support
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
This is a nuisance because you then have to reconfigure the device all over again.
You can backup your settings before you reset and restore them later. But that may just bring back the fault. Then again, at least you will know if the reset fixed the problem.
profeta64
May 19, 2018Luminary
So, currently I installed this update, coming back from DD-WRT.
The main reason why I left the original software was the issue with openVPN, which has been corrected on this beta/hot fix version.
I made the current configuration of the router from scratch, after to have performed the 30-30-30 reset procedure.
I think then that if I will reset again the router, and restoring the configuration will not make any differences.
Isn't it?
- michaelkenwardMay 19, 2018Guru - Experienced User
Restoring the configuration may also restore the bugs that you saw before the reset.
Try it. If the same pre-update problem exists reset and then do not restore.
- profeta64May 21, 2018Luminary
So, I choosed to use the previous V1.0.9.28 firmware, applied directly over the V1.0.9.30.
Now I got full speed :smileyhappy: -> speedtest.net at 32mbps as my line
The drawback is that the VPN now it is not woorking... :|
- Blanca_OJun 12, 2018NETGEAR Employee Retired
Hi All,
Blanca
Community Team
