KenDRider
Feb 24, 2018Aspirant
Extremely slow 2.4 GHz network
I was out of town and one of my security cameras reported it was offline and another was online but barely streaming. When I got home I noticed all of my Wifi connected devices were extremely slow. I...
- Jun 12, 2018
Hi All,
A new firmware update is available. Please update the firmware to 1.0.9.32
https://kb.netgear.com/000059134/R7000-Firmware-Version-1-0-9-32
Blanca
Community Team
michaelkenward
May 19, 2018Guru - Experienced User
profeta64 wrote:
I think then that if I will reset again the router, and restoring the configuration will not make any differences.
Restoring the configuration may also restore the bugs that you saw before the reset.
Try it. If the same pre-update problem exists reset and then do not restore.
profeta64
May 21, 2018Luminary
So, I choosed to use the previous V1.0.9.28 firmware, applied directly over the V1.0.9.30.
Now I got full speed :smileyhappy: -> speedtest.net at 32mbps as my line
The drawback is that the VPN now it is not woorking... :|
- Blanca_OJun 12, 2018NETGEAR Employee Retired
Hi All,
Blanca
Community Team
