JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Diggie3
Dec 18, 2017Luminary
Sounds like DHCP might fail?
Can you connect a Windows PC and open a CMD window and type:
IPCONFIG /ALL
Do this when it's still working. See what your IP lease time is. Then try IPCONFIG /RELEASE * and IPCONFIG /RENEW *, then IPCONFIG /ALL again. Did your PC get a new IP address? (does it still access the internet?)
Finally wait until it loses access again and type IPCONFIG /ALL. Does it still have an IP address? Did it fail roughly when the lease expired?
IPCONFIG /ALL
spanishgringo
Dec 18, 2017Tutor
So far everything is working fine. I had had troubles with .12 and 14 so I flashed back to 1.0.9.6, did factory reset. Updated to 1.0.9.18 today and speeds and connectivity have been good.
- juchedDec 18, 2017ApprenticeTo add to this thread that enabling circle on this build does the same as all other versions I have tested. The internet speed tests slower and slower until eventually it is frustrating to use. Turn off circle and full speed is back. No reboot needed.
- HWAMDec 18, 2017Apprentice
spanishgringo wrote:So far everything is working fine. I had had troubles with .12 and 14 so I flashed back to 1.0.9.6, did factory reset. Updated to 1.0.9.18 today and speeds and connectivity have been good.
Great, please let us know if it stays that way.
- AlpineKid66Jan 09, 2018Guide
I hope it works for me.
- rogier64Jan 09, 2018Luminary
AlpineKid66 wrote:I hope it works for me.
I'm sure it will :-)
