JamesGL
Dec 19, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 08, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
spanishgringo
Dec 19, 2017Tutor
So far everything is working fine. I had had troubles with .12 and 14 so I flashed back to 1.0.9.6, did factory reset. Updated to 1.0.9.18 today and speeds and connectivity have been good.
juched
Dec 19, 2017Apprentice
To add to this thread that enabling circle on this build does the same as all other versions I have tested. The internet speed tests slower and slower until eventually it is frustrating to use. Turn off circle and full speed is back. No reboot needed.
