JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
aabshire
Dec 21, 2017Apprentice
I did this and it didn't work. I then also turned off the guest network and now running for 2 days with no problem.. Again, not a fix but at least I am stable until it is resolved. (?? Considering getting one of R8000 refurbs since I too only get about 45 mbs on my wifi will getting 420 on my wired! ??)
brdoddsjr
OFF TOPIC: what app are you guys using for mobile wifi throughput. Not loving the apps I've found.
