JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
HWAM
Dec 22, 2017Apprentice
I hope the Netgear engineers are really panicking now. This will involve more and more people. What a terrible end of the year for the one who made a big mistake. They don't even answer my support case anymore.
brdoddsjr
My opinion (free and worth every penny). I'm seeing the frustration with Netgear on this firmware release. I'm a Netgear fan. I also have a 5 camera Arlo system at home. We have had a couple firmware hick-ups on the Arlo side. I suspect that the engineering group doesn't communicate all that well with the support team. My experience is a new rev will show up soon without us knowing anything new.
- LaudekDec 22, 2017Star
Further to my post of 2017-12-19 11:01 PM.
I continue to have have instability in the 2.4Ghz band. The longest period of stability I had was roughly 36 or so hours. So continuing to tweak as I have devices that use the legacy tech. What for me is strange is that the devices have an IP address so are connected to the Router but can't move past it. They also don't show up in the router menu for attached devices. Hopefully a permanent solution will be found soon so we don't need to reset/reboot the router regularly.
- HWAMDec 22, 2017ApprenticeThey even reply to a ping.
