JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
AaronB483
Dec 24, 2017Aspirant
I have been struggling with this issue. Just to add another detail, Printing: I thought at first that I can no long print to my wifi printer(Canon) and my Brother laser attacted to the router. Nothing happen for 10 minutes but Finally both took off and printed. I have gone back to an older firmware and no chance. I am hoping that what one person in this discussion said they hope they didn’t damaged the router.
I am also thinking about Tomato. I’ve downloaded the Tomato and ready to install.
I will post to let you know how it worked out. It may be telling if I still have the same problem.
brdoddsjr
Dec 24, 2017Apprentice
TimePilot, how is your wifi speeds?
- TimepilotDec 24, 2017Guide
I haven't tested them yet - but no complaints from the family - more concerned about the stability and dropouts/failed connects
- gandmclarkDec 25, 2017Guide
V1.0.9.18.1.2.27
Just purchased this router and updated to the latest firmware. Most of my devices worked without issue but two did have a problem that I eventually solved.
Roku 2 device was getting code 003 ( unable to resolve dns ) problems, apps not working etc.
Motorola G5S Plus Android 7.1 WiFi OK but no outside internet no-connection.
I tried everything until I decided to go to security -> access-control and 'turn on access control' 'Allow all devices to connect' Even though I am not blocking any devices just enabling this got the above devices working. I'm not sure why the default setting of not enabling access control would stop the above two devices working.
- Davide66ITDec 25, 2017Initiate
That was a good suggestion.
I enabled device access control and authorized the devices.
I then again upgraded to 1.0.9.18 and no issue raised all devices work, even the Glaxy A3 that could not navigate internet at the first attempt.
- brdoddsjrDec 25, 2017Apprentice
Day 2 on the hot fix. Everything stable and speeds are good.
Smart Connect: On
QoS: Off
Guest Network: On
Using Reserved and DHCP on wireless devices.
- mzguyDec 25, 2017ApprenticeWhich version are you on brdoddsjr?
It would be great if Netgear communicated what a given version is expected to fix.
