JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Timepilot
Dec 24, 2017Guide
I haven't tested them yet - but no complaints from the family - more concerned about the stability and dropouts/failed connects
brdoddsjr
Dec 25, 2017Apprentice
Day 2 on the hot fix. Everything stable and speeds are good.
Smart Connect: On
QoS: Off
Guest Network: On
Using Reserved and DHCP on wireless devices.
- mzguyDec 25, 2017ApprenticeWhich version are you on brdoddsjr?
It would be great if Netgear communicated what a given version is expected to fix.- HWAMDec 25, 2017ApprenticeIs it fixed?? Is it really fixed?? Can anyone confirm a beta version is fixing the 2.4GHz problem? It would be a great Christmas present.
- shamarinDec 25, 2017Virtuoso
Just update and test if your problem is fixed. Mine didn't having any issues with 2.4 GHz even with 1.0.9.14. Also you can back to previous version at any time.
- brdoddsjrDec 25, 2017Apprentice
.20 Hot Fix. The link is above. Page 4 for me.
- mzguyDec 25, 2017ApprenticeThanks. Can anyone else confirm that .20 fixes the issue, or anyone for whom it failed?
