JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
brdoddsjr
Dec 27, 2017Apprentice
On the wireless side: Smart Connect: On, SSID: Enabled, Coexistance: OFF, WPA2-PSK(AES), Channel: Auto, Mode: Up to 600 Mbps, Transmit Power: 100%
QoS: OFF
Nothing on USB
Guest Network: only 2.4 enabled with open security
Access Control: OFF
One the WAN side the only thing is I disable IGMP
MTU: 1500
brdoddsjr
One other thing is i bought my R7000 when they first came out, so I've probably had every version of firmware. And I used it as an Arlo base station as well. This router has been upgraded may time.
